LSX motor mounts
Old Aug 23, 2006 | 08:31 AM
Phoenix1987's Avatar
Car: 1987 Trans Am
Axle/Gears: 4.10's
LSX motor mounts
I was going to install my Sphoon motor mounts yersterday when I noticed the access to the motor mount bolts is restriced. My questions is do I have remove the lower control arms to access the motor mount nuts? It looks like I might, any tricks?
Old Aug 23, 2006 | 06:45 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
It's possible to get to the motor mount bolts, but it tricky. It helps to have two people, a nice selection of extensions, long pattern open end wrenches too. There are some access holes in the K-member to work from....just use a flashlight to see inside.
Old Aug 23, 2006 | 08:48 PM
92camarors5spd's Avatar
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
Axle/Gears: strange 12 bolt 3.73's
yep i used an open end wrench on most of them. on and when you put them on an easy way to get the nut started is to get yourself a extenable pen magnet and put the nut on it and gently thread the bolt on to the nut. it works i sware. i just did this last friday. ive only got 2 wires to do and swapping gas tanks.
Old Aug 24, 2006 | 08:10 AM
Car: 1987 Trans Am
Axle/Gears: 4.10's
Thanks guys!
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
