She runs! Goodness I love open headers!!!!
Old Aug 28, 2006 | 07:51 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Ok gang... I got her running right before I went on vaca... Wired up the few last connections, and she fired on the very first try. She promptly shut off, which I was blaming VATS for..but I wasnt sure. Here is the vid...
jeepguy25 - Photobucket - Video and Image Hosting
So I built a VATS bypass box from about $11 worth of radio shack parts and an online diagram. The diagram turned out to be off alittle...so I used my brain and got it to work. I was just about to throw the box away when I switched one wire and got it to work. Car seems to run perfect. Nice idle...just like before I removed it from the camaro. And it sounds SICK!!!
Make sure you crank it up for this one...
YouTube - My swap...
Let me know what you think!
Justin
Old Aug 28, 2006 | 06:15 PM
ChrisH821's Avatar
Car: 88 sport coupe
sweet
Old Aug 28, 2006 | 07:20 PM
camaroboricua's Avatar
Car: 1990 Camaro RS
Engine: 355 c.u.
kewl!
Old Aug 28, 2006 | 10:56 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Running an all aluminum engine without the waterpump or radiator hooked up is disaster in the making
Old Aug 29, 2006 | 06:57 AM
Car: 86 Trans AM
Yup I agree. However, that was the longest and only time I ran the engine...I tried it about 4 times with the vats kicking in...sot hat was 2-4 seconds a pop. Then with the vats box hooked up i ran it for about 10 seconds to confirm it was working. Then i took the vid and ran it the final time. I could still touch the headers after I was done. Before I started it, I poured 50/50 in through the upper water pump inlet. A fair amount went in, and didnt come back out, so I figured it was atleast sitting in the motor in some spots. In fact the temp gauge barely started budging just as I shut her down. So I didnt do any damage to the engine... If I let it heat up to 260 degrees ..yes...that would be bad.
Thanks for the compliments and the concern! I still have some odds and ends to take care of. The radiator is now in and good to go. I have a few wiring things to clean up. Im on my way to spohn today to get the last of the front end parts that i needed. Only two major hurdles I have left are plumbing the brakes (all custom lines), and running the exhaust (hawks y-pipe/spohn crossmember issue). Ill keep you all updated!
Justin
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
camaro71633
Sep 1, 2015 10:24 AM
InfinityShade
Aug 22, 2015 08:00 PM
midias
Aug 22, 2015 01:42 AM
justin57
Aug 20, 2015 07:05 PM
