factory gauges with ls1 pcm anyone?
Old Sep 6, 2006 | 10:21 PM
92camarors5spd's Avatar
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
Axle/Gears: strange 12 bolt 3.73's
i just finished up my swap tonight fired it up and everything works pretty good. still a few things to do.
but i notice my gauges were off. is anyone done the swap and used there factory gauges and done the conversions using efilive, hptuner, ls1edit, etc?
if so let me know what you did to achieve the correct gauge readings.
thanks
Old Sep 7, 2006 | 05:37 PM
dingle's Avatar
Car: '83 Camaro
thanks
Well most of the info you can find in here by searching. The gas gauge is pretty well covered I know for sure. The tach can be adjusted with EFI Live (the LS1 uses a 4 banger pulse and the third gen uses a 8 cyl pulse). I was able to adjust a value (can't remember which one but I can find out) from a 6 to a little over 12 and my tach is almost dead on. Oil pressure may be looking funny but should still function. Speedo is covered on this site. Temp should work fine.
Old Sep 7, 2006 | 08:59 PM
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
sweet i guess i have to do some more searching. what keywords could i use to find the speedo? i have the tach calibrated.
Old Sep 7, 2006 | 10:35 PM
dingle's Avatar
Car: '83 Camaro
Sticky thread at the top of this forum has LOTS of good info compiled.
Speedometer:
- Electronically driven speedometer (90+ Camaro, 87+ Firebird)
Electronically driven speedometer can be reused on the LS1 swap. You will need to reprogram the LS1 computer so it will output the proper signal to the stock gauge cluster. Another option is to purchase a signal conversion box like the ones from the dealers links below to convert the signal outputted by the VSS (vehicle speed sensor) into the proper signal for the stock speedometer.
Old Sep 8, 2006 | 08:31 AM
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
i dont think you understand my question. what i am asking is that. what is the conversion, equation anwser to use on efilive or any other kind of tuning software. not how do you do it. i already know what you have to do. all my other gauges already work properly. and my tach is already calibrated.
Old Sep 8, 2006 | 11:30 AM
dingle's Avatar
Car: '83 Camaro
Well from what I understand you don't need to do anything but hook up the speedo to get it to work. I installed a Autometer gauge so this info is all from a third party and not first hand.
You will have to have the PCM programmed with the gear/tire combo for it to read correctly, but output pulses are like GMTech said, 4000 ppm, just hook up the VSS output wire from the PCM to the speedo input where the buffer box is on the dash harness, which is under the passenger side of the dash harness. If the guy programming the PCM isn't using a program that a simple speedo calibration on it, I would get it back and probably send it to someone else so it would be right. A lot of guys where I live use Bryan at PCM4Less and love the work he does.
https://www.thirdgen.org/forums/ltx-...do+calibration
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
Bstrang6
Sep 8, 2015 04:29 PM
NBrehm
Aug 25, 2015 11:49 PM
fonzie85
Aug 13, 2015 11:50 AM
