Lt1 wiring help. Please read.
Old Sep 20, 2006 | 09:40 AM
oneslowz28's Avatar
Ok Im helping my friend wire up his lt1 he swapped into his l98 equiped 91 z28. The lt1 he has is from a 94 and came with harness and computer. It also came with the 4l60e. It didnt come with the aldl port like he requested so what wires do we need to splice the aldl wires into?
Heres what im stuck on.
On the c210 connector on the lt1 harness:
Pin D Grey. Feed from fuel pump and fuel pump relay to prime connector. What does this wire to?
On C220 connector on lt1 harness
Pin D orange/black. Spark retard request. What does this wire to?
Pin E Tan/Black. tps signal? what does this wire to?
Pin F Tan . Serial data signal. What does this wire to?
Pin J Dk Green/White. Fuel pump relay control. What wire on the fuel pump relay does this wire to?
C230 connector on lt1 harness
Pin B Brown/white. Service engine soon indicator feed. Im assuming this is the ses light. What harness and wire color is this in the 91?
Pin C white/black. Diagnostic signal request. What does this wire to?
Pin E Dk Blue . Theft Deterrent fuel enable feed. What does this wire to?
Pin F Dk Green. Ac signal request. What do you wire this to? (he wants to keep ac.
Pin G Pink. Power feed from Pcm Ignition fuse 5. What do you wire this to?
Pin H Light blue/black. Tcc switched power feed. What does this wire to?
Pin J Orange/Black. Park/ Neutral feed from transmition. What does this wire to?
Pin K Tan/black. Torque converter clutch control. What does this wire to?
C100 3rd gen bulk head
A4 Red. Power Distrubition (ignition switch). What does this wire to?
B4 Purple. Starting system (starter interlock) Is this used?
F4 Pink/black. Power distrubition (Computer comand control, Efi, Tpi) What does this wire to?
When wiring up the Aldl From a 94 So my Tuning cable will work what wires need to be spliced where?
When wiring up the Fuel pump is there only 2 wires that come off of the lt1 harness to the fuel pump relay?
Hes had this car sitting with the lt1 in it for 2 months now and we cant figure out what the wires i listed above go to. any help will be greatly appreciated.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
Bull86
Aug 10, 2015 05:43 PM
