LS1 ECM programed
Old Sep 25, 2006 | 05:08 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
LS1 ECM programed
Can I have the basic things taken off to swap a LS1 in a 3rd gen by mail order company or is it best to buy a soft ware like edit and do these thigs myself since I'm only going to do a cam swap. I know I'll have to do some tunning on it when I get this done I do the cam swap.But I have looked at some mail order programs and they are $500 AND UP
Old Oct 3, 2006 | 09:12 PM
kcgperformance's Avatar
Car: 88 RS Camaro (Z28 Clone)
Engine: LS6, Vengeance VRX5
Transmission: T56, LS7 Clutch
Axle/Gears: Moser 12 bolt 3.73:1 ratio
Send it to Speartech or Vengeance Racing they can remove all the unnecessary items (VATS, Evap, EGR, downstreams etc), set your fan cut on/off, and give you a good baseline tune based on the specs of your cam, and whether or not you are running headers or aftermarket intake MAF etc. I don't have Speartech's number but Vengeance Racing is 678-513-7105. Talk to Ron and tell him what you are doing before you send it to them. They are located in Cumming, GA (just north of Atlanta) so if your close by you can take it directly to them.
-Kevin
Old Oct 4, 2006 | 03:42 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
There ia a guy in Ashland KY who tuned mine. He is very good at it. I piad him $150 to tune in my cam and delete pretty much anything and everything not needed. I can even delete the 02's and Maf if I want but have yet to do so. I dont know how far away you are but I would look into it. If you go to KyHORSEPOWER.com chck the banner at the top for BlueCat.
Old Oct 4, 2006 | 10:50 PM
trans_am_31's Avatar
Car: 85 Trans Am,79 Trans Am,02 Trans Am
Engine: 5.7 V-8 346 LS1
Transmission: Automatic
I just used HP tuners to delete everything and also to tune my car. There are a couple of tuning devices you can use. Good luck with whatever you choose to go with!!!
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
2012sergen11
Oct 13, 2015 07:38 PM
86White_T/A305
Sep 21, 2015 05:28 PM
dbrochard
Sep 19, 2015 08:13 PM
timonator
Sep 17, 2015 06:57 PM
