LT4 Hot Cam ?'s
Car: 1992 camaro
Axle/Gears: 3:73
LT4 Hot Cam ?'s
I was looking on gmparts direct and seen when useing this cam in a 95 below LT1 that the dowl pin on the end has to be knocked or cut a little to fit the opti in the wright place? Is this true?
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
You have to tap it in a little so the Opti will seat. The newer style optis use the pin to turn them, the older ones used a splined driveshaft from the cam gear. It really is very simple to do.
Car: 1992 camaro
Axle/Gears: 3:73
Ok is this something I will want to do in the block or out of it? And if I do it out of the block how do I know when I have drove it in far enuff?
Car: 1992 camaro
Axle/Gears: 3:73
Well kinda a problem there when I bought the motor he had just put in the hot cam. And I didn't get the old cam.
Car: 1990 Formula
Engine: 95 LT1
The pin needs to be in far enough that it doesn't hit the timing cover and not in so far that it doesn't go through the cam gear. I suppose you could tap it gently while it is in the engine.
1988iroc350tpi
Aug 14, 2015 07:52 PM
