LS2 won't run
Old Jan 13, 2007 | 12:48 PM
A10Beav's Avatar
Engine: LS2
Axle/Gears: Moser Ford-9, 3.50
LS2 won't run (SOLVED)
Hi guys,
My car has been in a shop getting an LS2 install, and after many delays they finally tried to start it. The engine turns but it won't run, it sounds like a distributor engine with a few wires crossed.
The engine was pulled from an '05 GTO by MTI and they installed a cam before shipping it. Any chance they installed it wrong?
The harness was made for the conversion and all sensors are new. Any chance a sensor is bad?
I'm just looking for ideas on where to start. It is getting fuel and spark.
Old Jan 13, 2007 | 06:57 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
If its getting fuel and spark then I seriously doubt its anything with your harness or sensors etc.
The cam sounds scary though. If its not in just right....
Old Jan 13, 2007 | 09:21 PM
A10Beav's Avatar
Engine: LS2
Yea, hopefully MTI wouldn'nt have screwed up something like that! I'll post up whenever we figure it out.
Old Jan 14, 2007 | 08:35 PM
LoneStar666's Avatar
Car: 2005 Pontiac GTO
Engine: 364ci LS2
Transmission: 6 speed
Axle/Gears: 3.46
i could be wrong, but sounds like they could have not installed the cam correctly
Old Jan 15, 2007 | 02:40 PM
xtremeirocz's Avatar
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
on the ls2 if you put the cam in too advanced and not dot to dot then you will have interference issuses. just take the front cover off and make sure it is dot to dot
Old Jan 18, 2007 | 11:20 PM
A10Beav's Avatar
Engine: LS2
I think I know what you're talking about. It's a small hole on the crank that needs to be lined up with a mark on the cam?
Old Jan 19, 2007 | 09:20 PM
A10Beav's Avatar
Engine: LS2
Found the problem: wrong coil packs installed. I had the harness made for the car and I told them they wer the round (Delphi) coils, but the connections were for the square (Mitsubishi) coils. I bought the coils on ebay and they were supposedly off an '05 GTO, but they could be truck coils too. I'm not sure who's at fault.
FYI- the connections are different even though they were made for the same engine. Thanks GM. Basically one pin per coil is reversed causing the coils to fire in the wrong order.
camaro11j
Sep 19, 2018 08:49 AM
E Rod
Aug 28, 2015 05:17 AM
Logan Bryant
Aug 27, 2015 11:52 AM
justin57
Aug 20, 2015 07:05 PM
Thirim
Aug 13, 2015 03:09 PM
