Turbo 350 LS1
Old Jan 25, 2007 | 12:57 PM
BT283's Avatar
Car: 1991 Camaro RS, 1993 Camaro Z-28
Engine: what engine, LT1
Transmission: did it come with one, 4l60
Axle/Gears: They spin (most of the time)
Turbo 350 LS1
Hey im kind of thinking about doing an LS1 swap, but i just need a few questions answered so i can decide to do this or not. First off, let me explain what i will be doing, i will buy an ls1 port the heads, put a cam in it, and put some good long tubes on it, and put a 150 shot of gas on it, put it in my 91 Camaro and basically be great dependable street/drag racer. In my opionion from what i have seen with other third gen ls1 swaps i think running 6.90s or better is a very easy goal. The problem is my car already has all the suspension(k-member, sphon torque arm, coil overs) bacially ever thing. so the first question is How can i bolt up my th350 to an LS1, and if i do bolt it up can i still use my torque arm? And second the motor swap mount that Hawks Third Gen sell will they bolt up to my k-member, i dont see why they wouldnt but just asking. thanks for the help and if you have any ideas or comment please tell me thanks
Old Jan 26, 2007 | 03:21 PM
Smokin87TA's Avatar
Car: 1987 Trans am
Engine: Cammin Ls1
Transmission: Th400 w/brake 5500 stall
Axle/Gears: Moser 9" w/ 4.11's
Well first of all the th350 will bolt right up to the ls1, there are 6 bolt holes in the trans but the ls1 is only threaded for 5. No big deal as 5 will hold it just fine.
If you are using a th350 torque converter you will need this adapter from summit http://store.summitracing.com/partde...5&autoview=sku . I used it an it worked awsome, you can also get a torque converter made for a th350/ls1 combo which you would not need this spacer.
for the torque arm you can either get an aftermarket one that bolts to the crossmember like spohn's http://www.spohn.net/product.cfm?productid=1303 or get the relocation kit for the th350 from summit http://store.summitracing.com/partde...5&autoview=sku
The swap motor mounts will bolt to the kmember and are actually made by spohn also.
As for going 6.90's i think that is completely reasonable. I currently will be in the high 10's with a cam only ls1 with a th400 and 9" with 4.11's. With a 150 shot i should be somewhere in the mid to high 9's. 6.90's should be about 10.70's in the quarter so with 8th mile gearing you could probably hit 6.90's on motor alone.
Hope this helps, Tim
Old Jan 26, 2007 | 09:33 PM
BT283's Avatar
thanks for the for the anwsers. The more i look in to this LS1 the more i think i will be more likely in the to 6.50 range on nitrous, which i where i currently am. but i cant drive my car and it sux
Orr89RocZ
Apr 25, 2016 08:28 AM
camaro71633
Sep 1, 2015 10:24 AM
Eric-86sc
Aug 24, 2015 09:01 PM
crazynights
Aug 21, 2015 06:53 AM
86White_T/A305
Aug 17, 2015 12:16 AM
