Oddball Lt1 question
Old Jan 31, 2007 | 05:16 PM
Sanjay's Avatar
I was wondering what oil pan and dipstick those of you with Lt1 swaps are using. My lt1 didn't come with a oilpan so i have the choice of what i use. Basically I just need to know if the LT1 and 350 TPI oil pans, oil pumps and dipsticks are the same and what I should be looking for for the best fit in a 3rd gen.
Old Jan 31, 2007 | 08:11 PM
RED396's Avatar
Car: 1989 IROC-Z
Engine: Was a 396 SBC, Now a 5.3l w/LS9 Cam
Oil Pan and dipstick
The LT1 oil pan has an oil level sensor in it. Any 87-up dipstick should work as long as you are using the third gen manifolds or headers. You could use a oil pan out of a third gen if you don't use the oil level sensor, as long as it for a one piece seal.
Old Jan 31, 2007 | 11:03 PM
Firebat's Avatar
When my LT1 dipstick broke I got one new from GM for under $20. But if you can save $20 by salvaging your old one, then do that.
Isn't the oil level sensor's only purpose to trigger a "low oil" light in the 4th gen gauges? If so, it would not be needed if you are using thirdgen gauges.
Old Feb 7, 2007 | 04:17 PM
Sanjay's Avatar
Thanks for the help
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
87iroctheo
Dec 4, 2016 11:47 AM
midge54
Aug 29, 2015 09:51 PM
redmaroz
Aug 16, 2015 11:40 PM
