Ls2 Intake on LS1
Old Feb 10, 2007 | 04:20 PM
85irocinjected's Avatar
Car: 1991 RS
Ls2 Intake on LS1
I can get a ls2 intake manifold complete with injectors and fuel rails for rather cheap, and Im thinking of swapping out my stock ls1 intake. Would I see a bigger increase in power over a ls6 intake manifold? Anyone have any ideas?
Old Feb 10, 2007 | 10:33 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
wont see a big increase over the LS6, plus the LS2 used a different 4 bolt throttle body.I think someone makes an adapter so you could use an LS1/6 style TB on the LS2. I guess it depends on how much your getting it for an LS6 usually go's for about $300.
Old Feb 13, 2007 | 09:03 AM
92camarors5spd's Avatar
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
Axle/Gears: strange 12 bolt 3.73's
there is no need really for a 90mm set up on a stock cubic inch ls1. now if you have a great set of heads and cam you might see a difference but you would send just as much on the ls2 intake that you would on a fast 90/90... for go with a ls6 or a 78mm fast setup.
Old Feb 13, 2007 | 08:49 PM
Car: 1991 RS
Thanks for the info..I guess I will just get a LS6 intake and try to find some LS6 heads.
dbrochard
Sep 19, 2015 08:13 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
timonator
Sep 10, 2015 07:55 PM
toronto formula
Sep 10, 2015 07:31 AM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
