motor mounts
Old Feb 24, 2007 | 04:25 PM
SlowCamaro88SC's Avatar
motor mounts
as for putting in new motor mounts, there is hardly any room to work with, do I have to tear down the front suspension? or is there another way to do this??
I'm just trying to bolt the mounts to the frame. there isn't any room to get the nuts/bolts in there at all. The old came off easy since they were rusted to the frame.
Old Feb 24, 2007 | 04:38 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
you put them on the same way they came off, through the cutout in the cradle by the lower arms
same deal
its fun
been there done it a bunch of times, its so much easier without an engine in the way however
good luck
Old Feb 24, 2007 | 10:48 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
I uesd an assortment of extensions ,swivels and expletives. It can be done by one person without tearing apart the suspension. It helps to put the bolt in from the bottom when you reinstall them.
Old Feb 26, 2007 | 02:54 PM
I could wire the bolts then pull them up I will try that should work thanks every one
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
