ls1. speedo oil problem need help!
Old Apr 1, 2007 | 11:23 AM
smokin91rs's Avatar
Car: 91 camaro rs
Transmission: t5
alright guys i swaped a 99ls1, auto into my 86 trans am(305tpi auto, digital dash) i got the car running a few days ago and runs pretty good has a small stumble off idle but i was runnning a open maf and no iat sensor, anways my speed0 was wired (ls1) green/white wire pcm50) to light green/black (TA dash) which on my TA diagram is the 4000ppm speed input wire, ive tried everything i hooked the buffer box all back in and still no speedo- am i missing a ground maybe? the speedo stays at 0mph all the time and is lit up being digital, also the oil pressure guage the only tan wires i have out of my ta dash is tan/black stripe or tan/white stripe, the tan/white is feeding my fuel pump prime. i had the (ls1 tan) hooked to Tan/black TA wire and had no oil pressure guage. any help is apperciated, could it be the pcm?
Old Apr 1, 2007 | 03:50 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: ls1. speedo oil problem need help!
Tan wire under the hood going into the C100 bulkhead connector will be the oil pressure gauge. PCM output from the LS1 PCM (green/white) should be hooked to the 4000ppm output wire (tan or green/white) which goes to the speedo.
Old Apr 1, 2007 | 08:39 PM
smokin91rs's Avatar
Car: 91 camaro rs
Transmission: t5
got it all working, i was looking under the dash for the tan wire, until i pulled the old tpi harness out and looked at it then relized it was under the hood, thanks
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
beachrodder
Aug 7, 2015 04:27 PM
