LT1 camshaft question
Old Apr 23, 2007 | 11:52 PM
85streetmachine's Avatar
Car: 1985 iroc z
Engine: 6.0L coming
Transmission: 4L80E coming
Axle/Gears: 10 bolt 3.73
looking to install a hydraulic roller into a LT1 i just bought and am wondering what the limits are on the stock aluminum heads??? i could rebuild heads as well, but am just looking to get about 375 HP and figure i could get away with using everything stock. i plan on porting the heads (mildly) and intake. also is there a good engine management system to buy, or should i find an old harness and computer and have them reworked and programmed?????
Old Apr 24, 2007 | 06:50 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: LT1 camshaft question
You could get 375 out of the heads easily, just remember to change the springs when going to a larger cam.
Best thing, get a stock ECM and harness to use.
Old Apr 24, 2007 | 12:05 PM
Car: 1985 iroc z
Engine: 6.0L coming
also will the throttle body and injectors support the 375-400HP range? if not what sizes should i use???
Old Apr 24, 2007 | 05:44 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
I don't know if you are doing your own heads or not but try www.eportworks.com He is working on mine I got a "port only" like $400 not bad for someone who knows his stuff. His site also gives you a setup around those hp#'s and his injectors and tb.
87iroctheo
Dec 4, 2016 11:47 AM
blackroc68
Sep 1, 2015 08:01 PM
midge54
Aug 29, 2015 09:51 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
