Is there a way to keep all emissions equipment during an LT1 swap...
Car: 1991 RS Convertible
Engine: 96 LT1
Axle/Gears: 3.45 9-Bolt
Hey all,
Very possibly dropping in an LT1 shortly. I know you have to use 3rd gen headers to get them to fit, but the LT1 exhaust manifolds dont use the same style emissions equipment connections that our orginal 3rd gen manifolds. Is there a way to use headers & all of the emissions equipment at the same time? I really dont want to have to "rig" anything with adaptors or small sections of hose.
Thanks,
Mark B
Thanks,
Mark B
Engine: 96 LT1
Re: Is there a way to keep all emissions equipment during an LT1 swap...
Does the clearance issue with 4th gen headers happen with the headers or the y-pipe?
Cause I was thinking of using shorty headers for a 4th gen and then fabing up a y-pipe to join them. That would be ideal if it will work. Any other ideas?
Engine: Many
Transmission: Quite a few
if you use 3rd gen headers that are emissions qualified, they'll have Air tubes and 1 oxygen sensor hole. At that point, you would need to add another o2 bung for the other header, and an egr port (if you really want to). So simply, 1 02 sensor is all that is 'really' needed.
keep the EGR valve on the manifold, and put a block off plate on the EGR inlet tube boss. GM even made the blockoff's for lt4 engines becuase the camshaft had enough reversion that egr was uneccesary. If anyone does a quick emissions inspection, they'll see that the valve is there, and not worry about the inlet tube. leave the egr soleniod and everything hooked up too. In jersey, I don't think the pop the hood anyway, just check with a mirror if a cat is in place.
everything else is straightforward. air tube to cat (if your car has it), evap canister, and thats pretty much it.
if you are using 96 and up OBDii Lt1, it might be a benefit to get an '8051 ecm and run OBDi, so you don't need the post cat o2's.
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
OLd thread, but....what about using all LT1 emissions equipment?
Engine: Many
You can certainly do that. The only thing that might be somewhat different is the charcoal canister. It's been awhile, I don't know if the LT1 cars had a canister in the front or the back(tank). if it was at the tank, it's probably easiest to use the earlier car's canister.
You could use the thirdgen charcoal canister, just might have to run new vacuum lines to it. The LT1 canister is in the back but the LT1 Charcoal Canister Purge Solenoid is mounted on the intake manifold.
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
I never even thought about using the 3rd gen canister. I guess it could work. The 4th gen LT1 canister is attached to the fuel tank?
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
No, the LT1 canister is not at the tank, but mounted inside the driver side quarter panel behind a little plastic shield that looks like the front inner fenders.
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
why go thru all the trouble of a swap to keep the emissions stuff in place.
Transmission: 4L80E/4L80E
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
bigjay89gta
Oct 15, 2015 08:04 AM
