hawks motor mounts
Old May 19, 2007 | 04:49 PM
MonteC's Avatar
Car: 86 Monte Carlo SS
Engine: LC2
Transmission: 2004r
Axle/Gears: 3.42 8.5" 10 bolt posi
hawks motor mounts
which way do they bolt up? I let mine get a little rusty and now i cant read the L and R sharpie.
Old May 20, 2007 | 09:08 AM
MonteC's Avatar
Engine: LC2
Transmission: 2004r
Re: hawks motor mounts
no one?
Old May 20, 2007 | 09:38 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
the inside is labled too! stamped on the u-part
the two front holes line up with the two rear holes were on your stock mount used to be. (the rear of the U-part hangs over should be toward the rear of the car)
Old May 20, 2007 | 09:44 AM
Engine: ls1, LB9
this is where it is stamped.
you can also see the angle of the mount and where I drilled a hole for the brake line tab
Old May 20, 2007 | 05:59 PM
MonteC's Avatar
Engine: LC2
Transmission: 2004r
AWESOME! Thanks a ton!
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
