notching k-member
Old Jun 6, 2007 | 07:46 AM
1987earthquake's Avatar
Car: 1987 Camaro Z28
Engine: 5.3L
Axle/Gears: 3.42LSD
notching k-member
can someone send me a pic with measurements on where to notch the k-member for a lsx motor.
Old Jun 6, 2007 | 08:48 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Re: notching k-member
No "exact" dimensions as there will be variances in each set up but this link has pics that should be enough to give you a good visual where to notch.
https://www.thirdgen.org/forums/ltx-...ompressor.html
Old Jun 6, 2007 | 12:31 PM
Engine: 5.3L
Axle/Gears: 3.42LSD
thanks that helps but I hope someone has measurements when they did a 5.3 or a 6.0.. If not I'll just go by this. I really think there should be a tech sticky on this. Maybe a moderator can get one started.....
Old Jun 6, 2007 | 12:41 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
This notch is only required to clear a stock LS1 F body A/C compressor. If your not running A/C you dont need to notch at all. There are brackets available for using your stock third gen compressor but its ugly as hell.
BTW all LS engines are the same physical size, 5.3, 6.0 etc etc. Its the accessory brackets, oil pans etc that change for each different donor vehicle.
Old Jun 6, 2007 | 01:39 PM
Engine: 5.3L
Axle/Gears: 3.42LSD
I am planning on using a/c. I refuse to use the old compressor I've seen it it looks like crap. Too much going on at the top of the engine bay. I know they are all the same. The reason I stated the 5.3 and 6.0 is because I'm getting the 5.3 out a truck "using truck accessories" and an f-body pan. I was just thinking someone would have the measurements when they used this engine setup in their 3rd gen.
Old Jun 6, 2007 | 02:16 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
To my knowledge no one has used the truck accessories with any success in a third gen. Your treading in dark waters now bud but someone has to be the first so when you figure it out post up your findings to help others. Good luck
Old Jun 6, 2007 | 03:59 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Only difference in the truck accessories and the LS1 is the placement of the alternator and P/S pump. The A/C compressor stays in the same place.
Old Jun 13, 2007 | 11:16 AM
6.LIROC-Z's Avatar
Engine: 6.0L LSX Carbed
Axle/Gears: 3.73 Strange 12 bolt
The alt in the stock truck location will not allow the hood to close.Believe me I tried. If you get it to fit I want pics. I have a 6.0L with fbody pan and accesories no ac with a stock k member and didnt cut a thing
With my 6.0L the distance from the front of the block to the serp. belt is longer than ls1.The water pump is longer and the inlet points in a different direction.
Old Jun 13, 2007 | 02:38 PM
Klortho's Avatar
Car: 1987 GTA
Yeah, I forgot that they used a different water pump.
Old Jun 15, 2007 | 07:13 AM
Engine: 5.3L
Axle/Gears: 3.42LSD
Did you use a stock hood? If so do you think it would fit under a cowl? I am using ac so I will need to cut the k member for that.
Old Jun 16, 2007 | 11:26 PM
6.LIROC-Z's Avatar
It wouldnt fit under my cowl hood. It would fit if the cowl on the hood was three feet wide and six inches tall in the front. Just buy a tubular k-member with the mounts and get fbody acc. for the front of the motor. you will not have to cut a thing and the hood clearance wont be a issue. It will save you a lot of time and effort if you do it this way.
Old Jun 18, 2007 | 11:05 AM
Engine: 5.3L
Axle/Gears: 3.42LSD
Is the a/c compressor, alt, and power steering pump all the same part #'s on the three diff setups(f-body, corvette, truck)? If so then all I need is the brackets and the water pump. Maybe I can just get the one bracket on the driver's side and space it to make it even up with the truck acc. on the pass. side.... What you guys think?
Old Jun 18, 2007 | 07:57 PM
6.LIROC-Z's Avatar
The truck water pump outlet points up at a 45* angle so if you get alt,p/s pump worked out the waterpump will be pointing above the rad. You need to buy a fbody w/p,fbody alt brkt, p/s pump bracket.I am not sure if the truck p/s pump itself is the same as the fbody pump.
I tried for weeks to get the truck stuff to work ( make brackets, idler pulleys, spacers, move alt to here, move p/s pump to there. finally got pissed went to the local gm dealer on a wed. and order less than $100 worth of brackets and bolts.By friday evening I had the acc. in the fbody location and the motor running while kicking myself in the a$$ for spending any amount of time scewing around with the truck acc. when people on this and other forums told me the same thing we are telling you! DONT WASTE YOUR TIME WITH THE TRUCK ACC.
Just my .02 worth good luck
Old Jun 19, 2007 | 07:18 AM
Engine: 5.3L
Axle/Gears: 3.42LSD
So the brackets for the f-body are less than $100 from a gm dealer???? If so I'll be going there this evening
Old Jun 20, 2007 | 12:11 AM
slick00m's Avatar
Car: 1989 Camaro IROC
Engine: 6.0 LQ9
I have a 6.0 in my 89 IROC with the truck brackets. I have it running, but it's like 6.LIROC-Z said, it won't even fit under a cowl hood. I think that the Jongbloed Hood looks like it's wide enough for the Alt. but looks like you'll have to do some cutting on the underside of the hood. So, it's f-body brackets for me too. But that means that I'll need a new intake and w/p. So right now I'm just running without a hood.
Old Jun 20, 2007 | 07:19 AM
Engine: 5.3L
Axle/Gears: 3.42LSD
I think I might be going with corvette brackets. little more expensive but it puts the alt above the power steering pump and I think the compressor is shorter so I might not have to notch my k-member. Can anyone verify this?
Old Jun 20, 2007 | 12:48 PM
slick00m's Avatar
Engine: 6.0 LQ9
The Corvette brackets bing the accessories closser to the block, so those brackets are going to push the ac comp. closser to the k-member. I'm not sure how much shorter the comp. is, but i bet it will still get into the k-member. I wonder how close it would be with the truck brackets and the Corvette comp. But then you'll have the issue with the alt. being to tall.
Old Jun 21, 2007 | 07:07 AM
Engine: 5.3L
Axle/Gears: 3.42LSD
the corvette compressor would not work with the truck acc.. would it? Are the corvette brackets closer than the f-body brackets?
Old Jun 27, 2007 | 01:21 AM
dunout's Avatar
what company would be a good to get a tubular K-member from ?
Old Jun 27, 2007 | 03:05 PM
6.LIROC-Z's Avatar
Hawks,BMR,Spohn,Thunder Racing. Theres a few
Old Jun 28, 2007 | 12:53 AM
dunout's Avatar
thanks were can i find the hawks one ?
Old Jun 28, 2007 | 09:45 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Now thats a tough one. Scroll up to the top of your page and click on the HAWKS link. They are the primary site sponsor here
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
Mdenz3
Sep 17, 2015 08:36 AM
luvofjah
Sep 10, 2015 10:41 AM
Stangski09
Sep 7, 2015 05:21 PM
NBrehm
Aug 5, 2015 07:57 PM
