No harness with LT1...should I go Painless
Old Jun 17, 2007 | 03:33 AM
Lowrider0308's Avatar
Car: 89 RS
Engine: 305 TBI
I bought an LT1 with everything but the intake manifold, wiring, and sensors. What would be the best thing to do....Get a painless wiring harness, or find a junk caprice/impala and take its wiring harness+sensors and splice into the 3rd gen harness.
Thanks,
Andrew
Old Jun 17, 2007 | 12:24 PM
85streetmachine's Avatar
Car: 1985 iroc z
Engine: 6.0L coming
Transmission: 4L80E coming
Axle/Gears: 10 bolt 3.73
Re: No harness with LT1...should I go Painless
I was in the same boat. I looked at painless, but the price was a little steep for me. I went on LS1.com and bought a harness and computer from a member there. He labelled every wire for me, and had all emissions and a/c stripped off of it. If you find one cheap enough, there are companies that will make a stand alone harness which is just plug and play and a little cheaper than painless.
Old Jun 19, 2007 | 12:43 PM
Firebat's Avatar
Try to get a wiring harness out of a 95-97 camaro/firebird. Also, try to get a 95 computer unless you have a 94, then you need a 94 computer/harness. I just know you can get all of the wiring schematics for LT1 camaros/firebirds online at shbox.com. All the sensors should be the same on any LT1 of the same year, no matter what car the LT1 is in. Manual and automatic cars have slightly different wiring harnesses.
Old Jun 19, 2007 | 04:30 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
I have one off a 95 there is some wires cut off it nothing major I dont think. $40 to your door.
Old Jun 24, 2007 | 09:48 AM
Grifter757's Avatar
Car: 87 IROC,
Engine: 370 LSx With Boost
Transmission: 4L80E
Axle/Gears: S-60 with 3.50s
I have a painless wireing kit brand new in the boc and computer I will throw in for $500. I need this gone.
Old Jun 25, 2007 | 06:29 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
talk to speartech.com , they make a very good (arguably the best) harness custom cut for your needs.. they are more expensive than painless but can also program your computer or sell you one custom programmed..
Old Jun 26, 2007 | 10:06 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Im voting speartech... John will not only get you a perfect harness and computer modifications, but will always be around for support if you run into issues. And he stands behind his products just like all other great vendors.
Justin
KO1
16
Oct 15, 2015 05:00 PM
88CamZ
Oct 8, 2015 10:29 AM
92firebirdchris
Exterior Parts Wanted
Oct 1, 2015 01:38 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
Eric-86sc
Sep 28, 2015 11:37 AM
