3rd Gen Fuel Pump Rating?
Old Jul 7, 2007 | 08:35 PM
tlove's Avatar
Car: 88 GTA - White
Engine: Was L98 - Now LS1 Powered
Anyone know what the fuel pump on a 3rd Gen is rated for (LPH)?
Have LS1 in 88 GTA and now wanting to put a small dry shot on it. Wondering if the original stock fuel pump can keep up with a little more or if it's time for a change.
Logging the injectors now they never exceed 76% duty cycle at WOT.
Thanks!
Old Jul 8, 2007 | 07:33 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Re: 3rd Gen Fuel Pump Rating?
I know others use the pump with success and so far I have yet to see anyone spray an LS1 using the stock third gen fuel pump. Maybe its been done but I haven't seen it. Its certainly not the norm
A new stock LS1 pump can support up to 500 rwhp safely so head cam motor with a 100 shot is fine. Your using an ancient pump not rated for much and although it might work is it worth the gamble to you to cook your motor? I've seen stock LS1 pumps go for 20 bucks on LS1tech. If you have the coin for N2O then I would recommend you upgrade the pump too.
Might work yes but if it doesn't its an awful big risk IMO so good luck. Let us know how she blows.... I mean goes
Old Jul 18, 2007 | 09:08 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i would NOT reccomend it...
drop a walbro in there ($100, for a boltin) and then i would happily reccomend upto a 150 wet shot... or a 100 dry one thats carefully monitored.
Old Jul 20, 2007 | 01:19 PM
tlove's Avatar
Car: 88 GTA - White
Walbro is installed. Was just wishfull thinking that I could get by without doing it. Really wasn't all that bad, just took a little time. I would say that anyone that's done it w/out help is a better man than me Wrestling the tank back in was the fun part.
Old Jul 20, 2007 | 02:46 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
once you've done it two or three times, it becomes no big deal. (assuming the tank is empty. lol)
i got curious.
according to the us department of energy:
1 gallon of gasoline equals 5.8 to 6.5 lbs.
so our 16 gallon tank could weigh 92 - 104 lbs.. plus the weight of the empty tank...
Old Jul 20, 2007 | 03:25 PM
Guest
Guest
Posts: n/a
Man that took a long time... and it was my own post.
https://www.thirdgen.org/forums/sout...pump-info.html
Stock pump is 150lph, +/-. Sorry I was late to the party though. Sounds like a 100 shot would have resulted in meltdown or real close.
Old Jul 23, 2007 | 09:31 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Running your injectors much past 80% isn't a good idea either. You start to loose control at that point as the injectors are off so little that they tend to get erratic. Anything past 90% is much like valve float.....not good when you are trying not to melt pistons.
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Newguy91rs
Aug 7, 2015 09:51 PM
