Reluctor ring part#
Old Jul 18, 2007 | 02:07 PM
(Sparky)'s Avatar
Reluctor ring part#
looking for a part number for a 40 tooth reluctor ring .This is the last part I nead to finish my lt1 swap.I am also using a 4th gen insterment cluster. So I dont nead a cable speedo conversion just a vss signal.Woot first post
Old Jul 18, 2007 | 03:28 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Re: Reluctor ring part#
Welcome aboard (Sparky) I cant help you but thought to suggest camaroz28.com theres LOTS of LT1 info over there. good luck!
Old Jul 18, 2007 | 03:41 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
What transmission are you going to run with the LT1? That would help out a bunch.
Old Jul 18, 2007 | 04:00 PM
(Sparky)'s Avatar
sry its a 700r4 wouldnt even use it if it hadnt just had a rebuild
Old Jul 18, 2007 | 04:40 PM
Klortho's Avatar
Car: 1987 GTA
Have you done the search on what Firebat had to do for his 700R4, his was rebuilt also and said that he would go with the 4L60E if he had it to do all over again. He ran into a bunch of problems getting his put together, just do a search in this forum and you should find it.
Old Jul 18, 2007 | 04:48 PM
(Sparky)'s Avatar
yes I did but he gives no part number for the ring. no big deal I will proly just call a local trans shop and get the part from them.
Old Jul 18, 2007 | 11:05 PM
Firebat's Avatar
Don't really need a part number if you go through a gm dealership/parts-dealer. Just call up a local gm dealer if you have one. Order a vss reluctor for a 95 z28, 4l60e. I think it was around $5 but I don't remember for sure. If you don't need it anytime soon, i could call up my gm dealer and get the number.
Old Jul 19, 2007 | 12:00 AM
(Sparky)'s Avatar
thanks for the reply but i think I will just get it from the local trany shop. The gm dealers in my earea pritty much suck.i will post the part num when I get it tomarow .just incase anyone els neads the info.
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
gord327
Oct 3, 2015 01:25 PM
FormulasOnly
Oct 2, 2015 05:52 PM
Numbah-1
Oct 2, 2015 08:27 AM
