LT1 no idle, runs ROUGH & smoke...
Old Aug 5, 2007 | 11:36 AM
JerseyMark's Avatar
Car: 1991 RS Convertible
Engine: 96 LT1
Axle/Gears: 3.45 9-Bolt
Hey everyone,
Good news = I got my LT1/3rd gen fired up this morning.
Bad news = Its not running well at all
-It wont idle. While starting, the engine will catch for a split second, but then dies
-If I hold the gas on a little, it will run, but extremely rough & smoke comes out the exhaust. And the exhaust smells like fuel.
I am guessing its an ignition problem, but I dont know where to start. Here are some details...
96 LT1
PCMforLess tune
New GM opti w/ MSD cap & rotor
45-50psi of fuel
I dont have a history with the Coil & Coil control module
Any suggestions?
Old Aug 5, 2007 | 02:04 PM
JerseyMark's Avatar
Engine: 96 LT1
Re: LT1 no idle, runs ROUGH & smoke...
OK I got it. Ended up being a combonation of two things...
MAF & MAP
One of the things I had tried earlier was disconnecting the MAF to rule it out. Then car wouldnt even start with the MAF unplugged. So I replaced the MAP sensor and then tried disconnecting the MAF again... Whala!! The car is running on Speed Density right now... BUT IT RUNS!!! Im am so pumped. I cant wait to get the accessories hooked up so I can take it out for a spin!!
P.S. Open headers are great!
Old Aug 5, 2007 | 02:38 PM
TexasLT1's Avatar
Car: '92 RS
good to hear you got it figured out. I was going to recommend checking the MAF as your issue sounds similar to what happened to mine a few years ago when one of the MAF signal wires broke
midge54
Dec 27, 2019 04:14 PM
Bradsaundry
Aug 12, 2015 12:34 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
Sherpajames
Aug 7, 2015 06:56 PM
