LS1/84 Camaro Swap Wiring
Old Aug 30, 2007 | 12:00 PM
Diabloformula's Avatar
I'm about ready to do the wiring here on this 84 camaro and was wondering where to wire into (C100,C230,C207,etc) was also wondering if anyone had any diagrams for what wires go where on these connectors.
Old Aug 30, 2007 | 04:00 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: LS1/84 Camaro Swap Wiring
checkout the FAQ stickys and my wiring posts in the conversions and hybrid forum of LS1tech.com
im about to leave work (its 5!!) but i have everything you need to know on there.
Old Sep 1, 2007 | 01:18 PM
Okay I think I have most of my wires figured out, but one, it's a red wire off the LS1 ECU, it's marked Ignition Power, now I have 2 red wires coming from C100, both of these wires I plan on running off the alt., one is for lights, etc, etc, the other is for the ingition switch now I was told by the people that did the harness that I don't need the red wire hooked up, I'm a little confused about that, does this Ignition Power wire coming from the ECU supply power to my ignition if I wouldn't have the other red wire from C100 or do I need to either tap into or completely hook into the ingition switch wire to supply a sgnal to the ECU.
midge54
Sep 2, 2020 07:13 PM
camaro11j
Sep 19, 2018 08:49 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
reiderz iroc
Aug 13, 2015 04:57 PM
92projectcamaro
Aug 6, 2015 01:20 PM
