lsx v. 383
Old Oct 4, 2007 | 09:21 AM
slow_roc's Avatar
Car: 86 iroc
Engine: sbc
lsx v. 383
So after long diliberting i've decided i sorta want to ditch the 383 afr superram setup and go with a lsx base motor with a single turbo. i was thinking like a 5.3 with a cam and ls1 intake and a 76mm turbo intercooled. im just wondering if anyones gone turbo on a lsx motor how bad was making piping, and such. i also was gonna use a 98 ls1 harness and pcm from a auto car to make it all go. i was thinking that the lsx turbo would allow the car to go mid-low 11's and still remain driveable, as apposed to a high compression big cam 383 were brakes (vaccum) and idling and such would become a issue. what do you guys think ?
Old Oct 4, 2007 | 10:17 AM
atc3434's Avatar
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
Re: lsx v. 383
No replacement for displacement, there are plenty of 5.7 and 6.0 liter LSx blocks out there. Sounds much more streetable like you say, as opposed to a big cam motor. LSx does love boost.
Old Oct 4, 2007 | 12:59 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: lsx v. 383
you might want to try to get hold of those guys from parish racing that did that chevy ss pickup.
check it out..
http://www.youtube.com/watch?v=e0ZTA...elated&search=
only thing is they dumped some major coinage on it. I read the basic read up and it was crazy.
Old Oct 4, 2007 | 03:54 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Re: lsx v. 383
If mid to low 11 is all your after stay N/A LS1 you can hit that and still be very driveable with decent head cam package. Heck drop a stock bottom end 6.0L in there with the L92 head swap with decent cam and run 10's streetable N/A
newZman
Feb 25, 2021 11:58 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Nervous2
Oct 8, 2015 10:53 PM
RaverRacerX
Apr 13, 2007 01:03 PM
