Starter...
Old Oct 11, 2007 | 05:56 PM
naterman35's Avatar
Car: 89' Camaro RS--
Engine: 305--
Transmission: Automatic
Axle/Gears: 2.73--
Starter...
Well these are the LT/LS guys and girls so i figured the bst place to go... I was told that the LT1 Starter would work on a 305... and its much smaller and easier to install and remove... anyone know this for sure... Aslo good place to pick one up?
Old Oct 12, 2007 | 06:55 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Re: Starter...
It works so long as you have the smaller flywheel which is almost certain on a 305 ( Side by side bolt pattern on the starter ) but if you really want a pimp starter the Corvette mini starter rocks and even sounds high tech. The LT1 starter is smaller than the usual so it fits in the very tight opening on the t56 but the Vette starter is smallest for stock offerings that is. There may be some smaller aftermarket ones out there
FormulasOnly
Sep 10, 2015 09:07 PM
MoJoe
Mar 15, 2014 09:57 PM
luvofjah
Apr 28, 2013 01:37 PM
zeeboid
Jun 9, 2004 04:22 PM
