Something interesting for your LS1
Old Nov 22, 2007 | 07:48 PM
KBcobra's Avatar
Car: 92 Chevrolet Camaro RS
Engine: 3.1L V6
Well guys, on my quest for more info on my possible LS1 swap in winter of 2008, i was looking at LS1Tech and ran into this new product from painless. For those thinking about doing an LS1 swap and planing to use LS1 Edit this might be worth your time http://www.painlessperformance.com/w...?SearchField=2
*****EDIT*****
Here is that link from LS1Tech
http://www.ls1tech.com/forums/showthread.php?t=814415
Old Nov 23, 2007 | 10:07 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Re: Something interesting for your LS1
Eh...thats been around for awhile. Problem is its like $1k-$2k. AND you have to use their programming software.
You can get a stock harness dirt cheap (usually comes with the motor) and do some simple mods to it and get it to work perfectly. And use whatever tuning software you want.
Or go to speartech and get a custom harness for like 6-700...
Not knocking the product...its just going to be wayyyyy out of the price range that many of us are willing to pay for that sort of thing.
J.
Old Nov 23, 2007 | 01:54 PM
KBcobra's Avatar
Engine: 3.1L V6
J.
Jegs sells that product for $1500, ECM, Harness, Tuning Software. imo thats a pretty good deal
Old Nov 23, 2007 | 03:35 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
$200 for a factory harness and PCM
$500 for tuning software
=$700, less than half the price of that set-up with all the same funcionality.
Old Nov 23, 2007 | 04:21 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Not to mention the "painless" harness is about as painless as you paying me a bunch to cut the connectors off a 4th gen harness and label the wires for you....
Old Nov 23, 2007 | 05:58 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
Back when I did my swap I bought my engine, pcm, harness, tranny and everything from speartech..they even ran it on the stand before they shipped it..
My knowledge base and the general knowledge base on this board has grown a lot since then, if not exponentially.. But at the time I did pay the extra to get a system that had been running on the stand, labled, programmed and ready to go.. Without it I may not of had the guts to swap at the time.
Now with my current knowledge I would have no trouble..but at the time (almost 5 years ago) it made good sense.. for example I never had to deal with the alternator problem so many LTx folks were having at the time, or vats, etc..
for some having the "little" things done already can help out alot.. Budget providing of course.
Old Nov 23, 2007 | 06:06 PM
Car: 86 Trans AM
This?
http://www.jegs.com/webapp/wcs/store...0002_378821_-1
Thats for the a cam, and the harness and conroller. No programming software I believe.
I think you can get the harness and module for 1300..but again, thats without the CaTool and software to mess with the tune.
You are right though...it is a decent solution. I just feel that the OE harness is more than capable of performing well...afterall, it is factory. And with guys like speartech making custom harnesses for half the price, and being able to use "standard" tuning software with the stock PCM...I still feel thats the best route for swappers and rodders.
Not a BAD option...just saying I wouldnt even think of payin that much for it with the other options available.
J.
Old Nov 23, 2007 | 06:41 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Ummm when I priced it out there was a 1 in front of that. Seriously 1350 bucks was what he wanted for plug and play. Thats a tad steep IMO 6 or 7 hundred I would have bought it
Old Nov 23, 2007 | 07:44 PM
Car: 86 Trans AM
Haha...holy crap~! I thought his harnesses were only 6 or 700 clams....
Wait... is that maybe for his "swap harness"? Like, not plug and play but wired so all you need is power, grounds, and gauge hook ups??
Because thats all I think you need for a swap. Most of the thirdgen harness is useless for the swap. And I think a lot of guys are running aftermarket gauges anyway.
The painless kit deals, much the same way that speartech's harness does, only with getting the motor up and running correct? Or does it also make your gauges and what not function? Because I could see paying 1k if it was TOTALLY plug and play and made your gauges function and everything. Which is what speartech's 1k+ harness does correct?
I guess I never really researched this much because I knew I was going to make the stock harness do what I wanted. So I could just be blowing smoke out of my rear...
J.
Old Nov 23, 2007 | 07:47 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
yeah that was plug and play but still.... steeep man
Old Nov 23, 2007 | 07:56 PM
Car: 86 Trans AM
Yeah it is... Ill put up with a few hours of splicing and spaghetti straightening to avoid those prices... In fact, if I knew then what I know now, the only thing I would have bought pre-made would have been the hawks headers. Every other conversion part that I bought I ended up ditching and remaking on my own. haha.
Thats the way it goes though. I will say...painless does make some nice stuff though. Ive never had issues with anything else I got from them...other than price.
J.
Old Dec 1, 2007 | 09:35 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I've been looking into doing my own wiring for about a month now. I am pretty certain with the info I have and a couple of days to do it right I'm going to save about $1000. Just an issue of knowing what wires to connect to what wires and splicing them so that they won't mess up down the road. I just dread my slight OCD when I start bundling/hiding the wiring.
Old Dec 3, 2007 | 09:33 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
when i got my ls1 it had a wiring harness. I then sent it to john at speartech, and he made it stand alone. All i had to do was connect to battery constant and ignition, and plug it in. He removed all unnecessary stuff that i diddnt want to run (ac, emissions, etc) put a stand alone fuse block on it, wired in a stand alone aldl connector, fuel pump relay and wire, and brought out all the guage wires (speedo,tach,volts,oil). I did not have to use anything but this harness, no body or dash harness pieces from a 4th gen.
i paid 450 for the conversion yeah its 450 but NO headaches whatsoever. I also bought my hptuners software too so im at a grand and 1. had alot less work to wire it (a dumbass could not screw this up) and 2. have full tuneability at my fingertips.
ZZ3Astro
Aug 13, 2019 12:57 AM
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
86White_T/A305
Sep 21, 2015 05:28 PM
dbrochard
Sep 19, 2015 08:13 PM
timonator
Sep 17, 2015 06:57 PM
