No crank
Old Jan 11, 2008 | 06:44 PM
86iroc504's Avatar
Car: 86 Camaro
Engine: '03 4.8 vortec
Transmission: 4l60e
No crank
Fuel pressure is good now, I am getting spark through the spark plug wire on coil to the optispark wire, but dont think its going out to plugs because I took of one of the plug wires thats from the optispark and no spark was there.
By the way optispark,coil,IM,plugs,plug wires are new. The engine farts sometimes(small pop noise) when cranking but never cranks.
Old Jan 11, 2008 | 08:19 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: No crank
Optispark, injectors, fuel pump, plugs, wires, pcm, those are about the only thing that can keep the engine from starting, double check your grounds, check injector pulse with a noid light, find out if you have spark or not by pulling a plug, put the wire on it, and hold it to the head while someone is cranking the engine.
Old Jan 13, 2008 | 12:00 AM
86iroc504's Avatar
Car: 86 Camaro
Transmission: 4l60e
Re: No crank
after a few adjustments, it cranked on 1st turnover, and sounds steady. 86 camaro with '95 lt1 finally on deck!
Old Jan 13, 2008 | 09:24 AM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Re: No crank
Congratulations, THAT'S gotta feel good!
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
skinny z
Oct 5, 2015 06:23 PM
anesthes
Sep 30, 2015 07:48 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
