Couple of "harness source" questions
Old Jan 16, 2008 | 10:32 AM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
First off, I DID review the sticky at the top of the page, & also tried a couple of basic searches, but they didn't seem to return anything that addressed the two questions I have...
First off, I'm planning a 6.0 swap into my GTA, & I already have the heads & L76 intake (with injectors), although I don't have the engine or tranny yet. Trying to keep it as a fairly low-budget build, which rules out the pre-made harness option. Is there any reason why I shouldn't use the engine harness from the donor truck/van? (Or any reason why that would be "less than optimal"?) AFAIK, it should have the correct connectors/clips for the injectors...
Second, is there a preferred vehicle to get the donor harness from? I know that most people try to get the engine harness from an LSx F-body, but is that just because the lengths/sizes are closest to being correct, or is there some functional reason??
Thanks for any info guys...
Old Jan 16, 2008 | 11:05 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: Couple of "harness source" questions
The f-body harness is an engine harness, it unplugs from the other harness in the car where afaik the truck/van harness is all one piece like the old TPI harness.
Frozer!!!
Jan 19, 2024 04:55 PM
Cleotiz
Jan 6, 2018 08:56 PM
ezobens
Aug 19, 2015 10:29 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
