Any1 running no CATS exhaust?
Old Jan 22, 2008 | 11:43 PM
86iroc504's Avatar
Car: 86 Camaro
Engine: '03 4.8 vortec
Transmission: 4l60e
to all who are running exhaust/headers with no cats converter are you having any problems because I plan on running the O2 sensors but with no cats.
Old Jan 26, 2008 | 10:52 PM
drperformance's Avatar
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
Re: Any1 running no CATS exhaust?
Why would you have any problems with the O2s? Most guys around here run no cats, it will not effect the O2s in any way.
Old Jan 26, 2008 | 11:33 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
You dont need the rear O2's to run but regardless cat or no cat you neeed the front O2's unless you are running a carb then WGAFRA...
Old Jan 27, 2008 | 08:09 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
I'm running headers, no cats and not a problem one. But then again, I don't have rear O2s, only front in the headers.
Old Jan 28, 2008 | 12:41 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Long tubes, front O2s, no CATS, no problems. Have the rear O2s programmed out of the PCM, or buy O2 simulators for a quick fix. Ide still get it programmed out at some point though.
J.
Vintageracer
Jan 10, 2020 05:33 PM
transaero
Aug 31, 2015 01:14 AM
TheExaminer
Aug 26, 2015 04:59 PM
gta power
Aug 13, 2015 06:15 AM
