LT1 swap transmission shift cable
Old Jan 28, 2008 | 06:24 PM
86iroc504's Avatar
Car: 86 Camaro
Engine: '03 4.8 vortec
Transmission: 4l60e
Hey which transmission shift cable are you guys using that have swapped Lt1 in 3rd gen vehicle. The Lt1 cable or the cable that came in the 3rd gen vehicle?
Old Jan 28, 2008 | 06:43 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: LT1 swap transmission shift cable
You should be able to use the one from the 3rd gen considering the 4L60E is basically an electronic 700R4
Old Jan 28, 2008 | 07:13 PM
86iroc504's Avatar
Car: 86 Camaro
Transmission: 4l60e
the connection for the transmission is diffrent on the 3rd gen, it uses a screw to which you would screw it into the transmission shift on the transmission
Old Jan 29, 2008 | 07:40 AM
Klortho's Avatar
Car: 1987 GTA
It's may be possible to use the shifter linkage from the 700R4 on the 4L60E
midge54
Dec 27, 2019 04:14 PM
BlackphantomZ28
Apr 24, 2016 08:14 AM
mizz0313
Aug 12, 2015 06:45 AM
dhonda200
Aug 11, 2015 11:50 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
