LT1 Question
Old Feb 7, 2008 | 08:46 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
LT1 Question
I am looking at LTx IAC's. I notice from GM there are two different IAC's depending on year. 93-95 is 217-429, 96-97 is 217-433. However, aftermarket places label as same part.
Any idea what the difference is?
Also, I am looking on the tuning aspect side of it. What program tunes these ecms? I am looking for the "effective area" for the IAC. Can anyone help me out here?
Old Feb 7, 2008 | 10:02 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: LT1 Question
Dont know where you came up with those splits, 92-93 are the same and have the 4 pin square connector like a TPI, 94-97 has the flat 4 pin connector.
Old Feb 8, 2008 | 05:42 AM
Dale's Avatar
Engine: 350 S-TPI
Re: LT1 Question
ok, so 93 is just like an l98.
94-95 is 217-429
96-97 is 217-433
both are the flat 4pin.
Old Feb 9, 2008 | 10:36 PM
Fei's Avatar
Fei
Car: 1989 Trans Am
Engine: 94 383 LT-1
Transmission: Tremec 3550
Re: LT1 Question
the earlier of the 2 screws into the throttle body. the latter is hald in place with a bolt, like the vss.
Old Feb 11, 2008 | 10:13 AM
Dale's Avatar
Engine: 350 S-TPI
Re: LT1 Question
According to pictures. The 93 screws in like I was corrected.
The last 2 screw in like the TPS. But still have two different part numbers.
I am wanting to know the difference between the last 2
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
87iroctheo
Dec 4, 2016 11:47 AM
midge54
Aug 29, 2015 09:51 PM
redmaroz
Aug 16, 2015 11:40 PM
