3rd Gen K member notching for AC on LS1 Swap
Old Feb 9, 2008 | 09:53 PM
Bradlyj8Z28's Avatar
Car: 1991 Camaro Z28
Engine: 2002 SS LS1
Transmission: 6 speed
Axle/Gears: Auburn 3.42
I have only seen a few pics of notchs for the ac compressor, but mine is hollow and everyone else looked solid. So, stupid question, did you guys cut it and then weld plates to close it up? Also, the 2 L shaped brackets up front, is it okay if I dont run those? Thanks for the help...
Old Feb 10, 2008 | 08:35 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Re: 3rd Gen K member notching for AC on LS1 Swap
Yes they are hollow the pics show the 1/8" plate we welded in. Lots of pics in the link from the sticky here;
https://www.thirdgen.org/forums/ltx-...ompressor.html
Old Mar 11, 2008 | 11:56 AM
Engine: 2002 SS LS1
Thought I would post a few pics of mine for others to see as referance..
Old Jul 3, 2011 | 07:53 PM
0078red1's Avatar
Car: 1990 camaro RS
Engine: 1998 ls1. 5.7L
Axle/Gears: 4th gen rear end for got the gears
Is it ok if the ac compessor is touching the crossmember after the notch is made my is just bascily hugging it. Or will it affect the engine
Old Jul 3, 2011 | 08:12 PM
diablizzard's Avatar
Car: 86 Camaro Z28
Engine: LT1 200cc Ai heads and cam
Axle/Gears: 4.10:1 Zexel Torsen
Those bracket are for support in the front. The third picture shows the one is trimmed to fit around the compressor and notch
Old Jul 3, 2011 | 08:13 PM
Engine: 2002 SS LS1
I wouldn't want it touching. You will feel the movement of the engine and ultimately break either the compressor, mount bolts or something else.
sweet_87_iroc
Sep 25, 2015 10:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
