looking for a COMPLETE LT1 INTAKE SET UP
Old Mar 5, 2008 | 08:25 PM
camarokid 92's Avatar
Car: 1992 RS Camaro
Engine: a LT1
Transmission: right now a 700r
Axle/Gears: original
sorry wrong place to put this
Last edited by camarokid 92; Mar 6, 2008 at 08:09 AM. Reason: Automerged Doublepost
Old Mar 5, 2008 | 08:41 PM
Car: 1992 RS Camaro
Engine: a LT1
looking for a COMPLETE LT1 TPI SET UP
HEY GUYS I JUST GOT A 1995 LT1 MOTOR FROM A FRIEND THAT DIDNT WANT IT AND IM LOOKING FOR A COMPLETE TPI SETUP FOR IT IF ANYBODY HAS ONE LET ME KNOW. IM ON A TIGHT BUDGET CUZ IM IN HIGH SCHOOL STILL BUT I REALLY NEED ONE.
Old Mar 5, 2008 | 08:46 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: looking for a COMPLETE LT1 TPI SET UP
TPI won't work on an LT1, are you referring to the intake manifold by chance?
Old Mar 5, 2008 | 08:56 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: 305 TPI swap for 383 stroker
does it not have an intake on it now? It would probably be easier to run it with the lt1 intake setup on it.. what all do you have?
Old Mar 5, 2008 | 09:01 PM
socal's Avatar
Car: 91z,97ws6,98fb,87&90jeep,05 yz250
Engine: 5.0tpi,5.7LT4,5.7LS1,4.2I6,5.7TPI,1
Transmission: t5,4l60e,
Re: looking for a COMPLETE LT TPI SET UP
first off is your car tpi or tbi right now. if its tbi you can get a carb intake and a tbi adapter (best choice) second if its tpi you can make a distributer fit in the back of an lt intake, but ether way you wont get the most out of the tuning capability's of converting the wiring harness
Old Mar 5, 2008 | 10:53 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
LT1 needs a LT1 intake. TPI will not work
Old Mar 5, 2008 | 11:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Sorry if this is confusing, but the originator was posting about this in other threads. I tried to get them all consolidated into this one, but it came out weird.
Old Mar 5, 2008 | 11:58 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
TPI can work on LT1, I guess you guys just havent seen the Accel baseplate. It was designed for using the superram on an LT1, but technically since the superram plenum and runners can be swapped onto a stock TPI baseplate, you should be able to install a TPI on an LT1 using the baseplate
Old Mar 6, 2008 | 06:08 AM
Klortho's Avatar
Car: 1987 GTA
Oh Lord, why would anyone want to do this?
Old Mar 6, 2008 | 07:58 AM
Car: 1992 RS Camaro
Engine: a LT1
it doesnt have an intake on it. thats what im looking for
yes sorry about that im looking for a intake manifold
Last edited by camarokid 92; Mar 6, 2008 at 08:00 AM. Reason: Automerged Doublepost
Old Mar 6, 2008 | 10:44 AM
five7kid's Avatar
The lingo can be confusing. "TPI" here refers to a specific induction system used on 3rd gen V8's from 1985-1992.
LT1 induction is it's own set-up. It was used in Vettes from 1992-1996, and in f-bodies (4th gen) from 1993-1997. Just to confuse things, Vettes also had an "LT4" configuration, but let's not get into that right yet. The LT1 with some slight variations was also used in full-size sedans like Caprice and Road Master.
You need more than the intake manifold. You need the complete injection system, PCM (powertrain control module), harnesses, and sensors. There were changes made over the years, so if you don't get a complete system from one car, you need to know what you're getting.
The sad part is the engine is the least of it. You can buy a complete used LT1 engine, transmission, PCM, and harness ready to install for about $1200. A used engine will go for a couple hundred bucks. So, having what you've got isn't a big advantage. However, search on-line resources such as eBay, craigslist, racingjunk, and see what comes up for you.
And, let's move this to the subforum. You've got two threads going now, I'd combine them but it wouldn't track well.
Old Mar 6, 2008 | 04:35 PM
socal's Avatar
Re: looking for a COMPLETE LT1 INTAKE SET UP
this is true but i thought accel stoped making that baseplate for th ltx due to lack of sale's but this is what i found
might be an easy way to get an ltx in a car with out the wiring mods saying the distributer hole is in the rear
http://www.lingenfelter.com/store/74197.html
http://www.fuelinjection.com/sbsr.html
Part Numbers:
74131- Fits all Small Block Chevy V8's (except '92-up LT-1)
74131L- Fits '92-up Corvette LT-1 and Impala SS
74131F- Fits '93-up Firebird and Camaro with LT-1
Terrell351
Jun 13, 2021 01:13 PM
midge54
Dec 27, 2019 04:14 PM
Casey Meyers
Mar 2, 2016 10:46 AM
KO1
Aug 31, 2015 06:31 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
