okay 355lt1 comming out for 383LT1...tranny and motor or just motor?
Old Mar 14, 2008 | 09:15 PM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Okay guys I just traded my mild 355 for a 383 LT1. Should I pull the motor and trans together or pull just the motor?
IM starting to think motor and tranny??
Here are the new motor stats
383LT1 (harshaw racing)
CamJoe Overton 234/242 .568/.540 111lsa+2
Crank Eagle 103523750
Rods Eagle CRS60003B0
Pistons JE 170817
Caps & StudsPro-Gram 4 bolt caps
Oil PumpMoroso 22135
Oil PanMoroso 20205
Timing ChainCloyes Double-Roller p/n 3145
Lifters Comp 850-16
Rockers Comp 1305-16 (1.6, 7/16 Stud, NSA)
Rocker studsARP 134-7103
Head studsARP 134-4001
Valve Spring LocatorsCC-4705-16
Valve Spring LocksCC-613-16
Valve Spring RetainersCC-795-16
Valve SpringsPAC 1518PAC 1518
PushrodsLukovich Hardned
Premium Nitrided Beehive LS1 Spring Guide PlateIksyOD: 1.290'
ValvesManley 2.00 (11500-8) & 1.56 (11501-8)130 lbs @ 1.800' 337 lbs @ 1.150'
LE2 Heads.2 139/110Lift: 0.650'.3 191/141.4 241/171.5 271/182.6 275/191.650 277/19528" InjectorsSVO 36lbs
Electric Water PumpMEZ-WP118HD
Compression9.75:1
Dyno'd 400WHP
Should be fun bc Im thowing a 150 shot at it
Hellllo 10s
Jay
Old Mar 15, 2008 | 09:06 AM
Firebat's Avatar
Re: okay 355lt1 comming out for 383LT1...tranny and motor or just motor?
If you are pulling the motor from the top, just the motor.
Old Mar 15, 2008 | 09:28 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
For ease of joining the two together and install, pull them both.
Old Mar 15, 2008 | 06:13 PM
Jay_rich's Avatar
Car: 1987 Z28
ya i ended up pulling both. Took 5 hours to do both. Pulled the 355 and the 383 was in and wired 5 hours later. Still have exhaust and coolant lines.
Jay
evilstuie
Jan 9, 2020 08:29 PM
Steve78LT
Feb 24, 2016 12:15 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
