Lt1 air intake
Old Mar 16, 2008 | 06:45 PM
86iroc504's Avatar
Car: 86 Camaro
Engine: '03 4.8 vortec
Transmission: 4l60e
Lt1 air intake
hey is anyone using the air housing box off the old camaros that goes from the throttle body and splits up into 2 chambers that runs to the front of car for air? Would this be better for air circulation? I am just running a K&N filter to the elbow of that connects to throttle body
Old Mar 16, 2008 | 08:26 PM
Firebat's Avatar
Re: Lt1 air intake
The stock tpi camaro air box is very restrictive, not good for the LT1.
Old Mar 16, 2008 | 09:10 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
Re: Lt1 air intake
I took a piece of 4 inch mandrel bent exhaust pipe from summitracing and cut it to fit. Sprayed it with bedliner and good to go..
you can see it in this thread post #17 of "project 82lt1 about to live again" page two of the lsx/ltx forum.. can't seem to post a link that works, but its there.
it could be made to go either direction.. even if that sort of design wouldn't work it is pretty easy to make something to fit.
Old Mar 19, 2008 | 09:23 PM
86iroc504's Avatar
Car: 86 Camaro
Transmission: 4l60e
Re: Lt1 air intake
has anyone tried any of that aftermarket cold air kits that for the 93-97 F-bodys? will these fit in the 82-92's ?
Old Mar 19, 2008 | 10:17 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
Re: Lt1 air intake
There is a guy on here running a newer GTO cold air on his LS1 swap. It would be the same principle as an LT1.
Old Mar 20, 2008 | 03:33 PM
socal's Avatar
Car: 91z,97ws6,98fb,87&90jeep,05 yz250
Engine: 5.0tpi,5.7LT4,5.7LS1,4.2I6,5.7TPI,1
Transmission: t5,4l60e,
Re: Lt1 air intake
follow the link to see it
1992 Trans Am
May 10, 2023 07:19 PM
midge54
Dec 27, 2019 04:14 PM
stalkier
Dec 6, 2015 11:25 PM
kyle5647
Aug 15, 2015 11:56 PM
