Starter
Old Apr 25, 2008 | 06:36 PM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
Starter
Can i use a LB9 T5 starter on an LT1 T56?
Old Apr 29, 2008 | 07:31 PM
Bradlyj8Z28's Avatar
Car: 1991 Camaro Z28
Engine: 2002 SS LS1
Transmission: 6 speed
Axle/Gears: Auburn 3.42
Re: Starter
I dont think so, I believe the LB9/L98 starters are phisically bigger. The easiest thing to do is call autozone or advance or something and get the part numbers for each, or go up and have them pull an LT1 stater off the shelf and look at it....
Old Apr 30, 2008 | 09:28 AM
BCdawg57's Avatar
Re: Starter
I knew the LT1 starters were smaller, but i just didnt know if the teeth on the flywheel were the same, and if it would fit. Guess i will find out when i try to bolt it up!
Thanks for the help.
Jake
Old Apr 30, 2008 | 10:38 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: Starter
Probably wouldn't last long, you're taking a starter designed for an 8:1 compression motor and putting it on a 10.5:1 compression motor. If you can get an LT1 starter, get an LT1 starter and put on it.
Old Apr 30, 2008 | 06:44 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
LB9's were 9.3 to 9.5:1 CR.
It'll probably work, but why is it an issue?
Old Apr 30, 2008 | 09:11 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Re: Starter
I've been using my LB9/5 spd starter for years on my sisters LT1/T56 swap
Also been using one on my dads L98/T56 and my own 355/T56 pushing 10:1 compression. Starts up every time with no complaints from the starter
Just used one on my friends destroked 400. Cranks easier than it did with the larger starter.
I do beleive, that the LT1 starters are better.
-jason
Old May 7, 2008 | 10:07 AM
BCdawg57's Avatar
Re: Starter
well its not really a problem...but i wanst going to buy a new starter if i didnt have to.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
