Help On a LT1 Swap...A Few Questions...
Old May 16, 2008 | 11:45 AM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
Transmission: LT1 T56
Axle/Gears: 3.73 Moser 12 Bolt
Hey guys - my 383 LT1 is almost done but I'd like some opinions / input.
1. If I replace my throttle body to a 58mm unit, am I going to have to swap my sending units from the stock TB into it? It seems to me that most aftermarket throttle bodies do NOT come with any sensors.
2. With a ~450hp 383 i know I'm going to need bigger injectors. But what's a reliable manufacturer to go with? And what size? I was looking at 30 lb/hr injectors from Accel on ebay but I'm not sure...
3. I've upgraded to a 1995 opti spark - but I have *for now* a 1994 harness. Do I need to buy the opti spark harness to make the setup work?
4. I'm planning on running A/C delete, AIR delete, EGR delete - so I'm thinking my computer will need a fair rework - any recommended sources to try?
Thanks a lot guys!!
Tyler
Old May 16, 2008 | 06:13 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: Help On a LT1 Swap...A Few Questions...
Thanks a lot guys!!
Tyler
1. Yes they dont come with sensors.
2. www.racetronix.com
3. Yes it wont work with the connector on the earlier harness.
Old May 16, 2008 | 08:38 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
If you go with the 58mm tb you will have to open up your intake to 58mm.
Old May 17, 2008 | 03:20 PM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
Thanks for the tips so far gents! I'm waiting for my opti spark and timing cover to come in, then the top end goes together. I've ordered fuel-rail adapters (quick connect to 6 an) and I'm going to pick up my TB and injectors soon.
Then once I get some money saved back up I gotta find me a T-56 :-)
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
