LS1 & Wiper Motor Interference
Old May 13, 2008 | 11:42 AM
super_kev's Avatar
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
I'm having a problem with installing the wiper motor (variable speed control) on my '85. It is hitting the rear part of the LS1, and I can't move anything to get it to fit. Has anyone else had this problem?
Old May 13, 2008 | 02:39 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Re: LS1 & Wiper Motor Interference
I had issue with my 87's washer pump...which is installed in the wiper motor housing. I ended up pulling the pump anyway beacuse I decided to run a 4th gen water bottle.
But it would have been tight if I decided to keep it. I think I actually broke a piece of the cover off the wiper motor because I didnt realize it was going to hit. Oops..
Here is my space. I could probably get the pump back in if I tried. Im not sure if the 85's motor and all is different though. So if it is..just disregard everything I said.
J.
Old May 13, 2008 | 08:48 PM
wedjim's Avatar
What headers are you running on your combination?
...Jim
W.E.D.
Old May 13, 2008 | 10:23 PM
super_kev's Avatar
Car: '85 TA
Thanks ghetto. That looks like my '85 wiper/pump. I didn't think I could pull the washer pump without breaking something, but I'll have to take it apart and look again.
wedjim, I'm almost positive he has Hawks headers.
Old May 14, 2008 | 06:25 AM
Car: 86 Trans AM
Yup...Hawks/Stainless Works.
kev... That washer pump just slides out I believe. I cant remember anything holding mine in. There are two flat blade terminals at the top. One is perpendicular to the other. Just give it a wiggle and I think they pull out.
Something made me have to pull mine out though...So maybe give that a try. You could also pull the cover off all together, get the engine in the car, then you might have space to put the wiper motor cover back on. Sort of like an order of operations type of thing.
Good luck!
J.
Old May 14, 2008 | 03:45 PM
firechicken76's Avatar
Car: 88 Trans am GTA
Engine: 2002 Ls1
Transmission: t-56
Axle/Gears: Ford 9" 4.11 gears w/ locker
ive got a wiper motor installed but it doesnt work
Old May 14, 2008 | 08:44 PM
wedjim's Avatar
Hawks, I was afraid you would say that. LOL
Once I win the lottery, i'm down with the $800 headers, but until then, it looks like manifolds for me. I would rather spend the money some place else right now......until that is the last thing, or someone like Hedmann makes headers for $350-400....or less.
Dam#, They do look sweet though!
...Jim
W.E.D.
Old May 14, 2008 | 09:25 PM
tuske427's Avatar
Car: 1984 Trans Am
Engine: 2002 LS1
Transmission: 6 speed
Axle/Gears: 3:73
For the earlier third gens the washer pump does interfere. I ground mine off when I installed it as I used the washer resavoir for the coolant overflow (computer took the location of the original overflow) so the car was officially without washer fluid. Not a terrible loss in So Cal.
Hey Firechicken- did you ever get that one working??
Old May 15, 2008 | 07:50 AM
Engine: 2002 Ls1
Transmission: t-56
no, havent even looked at it, ive been busy getting ready to do my buildup, ill look at it when i pull the motor.
Old May 17, 2008 | 10:19 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
my 88 wiper motor clears just fine. it has the connector that faces the passenger side.
can i remove the lower half cylinder on the newer style wiper motor?
Frozer!!!
Jan 19, 2024 04:55 PM
Randomtask2
Aug 26, 2015 03:34 PM
zayne0
Aug 24, 2015 07:22 PM
86White_T/A305
Aug 17, 2015 12:16 AM
slade5612
Aug 11, 2015 07:19 PM
