lt1 harness question
Old May 26, 2008 | 10:23 PM
kyle88transam's Avatar
Car: 1986 Trans Am
Engine: soon to be a iron block 5.7 lsx
Transmission: 4l80e
Axle/Gears: 9 inch
I just purchased a 94 LT1 out of a camaro w/o a harness or ecm. I want to know if a harness and computer out of a caprice/ impala would work. I know the ecm mounts differently, but are the sensors the same? I tried searching but it was down at the time.
thanks Kyle
Old May 27, 2008 | 08:06 AM
Firebat's Avatar
Re: lt1 harness question
All the sensors should be the same if its from a 94 except the impala/caprice harness might want 2 knock sensors instead of one. The harness will be slightly different but it would work.
A 96-97 harness and computer won't work on a 94 setup just throwing it on there but it could be made to work.
If you have a 4L60E keep in mind a 94 4l60e is not interchangeable with any other 4L60E. 95-97 4L60E's are interchangeable with each other or are the same.
Hopefully some impala/caprice LT1 swap experts will chime in with more information.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
