LT1 drive gear/stub shaft
Old Jun 14, 2008 | 08:51 AM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
On the '93-early '94 LT1s, I've read that the sizes of the stub shaft are different than late '94s and up. Can a latter style ('94 and up) shaft and gear fit into a '93 LT1 Block so that I can use the post '94 distributor setup?
Old Jun 14, 2008 | 09:22 AM
WhiteBlaze's Avatar
Car: 1984 Firebird
Axle/Gears: 3.42's
Re: LT1 drive gear/stub shaft
The cam and the timing cover are different, so you would need to swap those to move over the the later style...
Check this out for doing the swap.
http://www.noid.org/~muttvette/opti.html
Old Jun 14, 2008 | 10:43 AM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
That is exactly what I was looking for.
Old Jun 14, 2008 | 09:28 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Actually, the '94 is still a splined non-vented opti, you will need to go with the '95.
Old Jul 4, 2008 | 09:11 PM
fullsize fun's Avatar
Car: 1986 pontiac bonneville
Engine: LB9 305
Transmission: MK6 T5
not if you have a b body engine,94-96's iron headed lt1's got the vented opti.
1984HO
Mar 19, 2021 11:59 AM
midge54
Dec 27, 2019 04:14 PM
jharrison5
Aug 19, 2015 05:53 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
MENINBLK
Aug 5, 2015 11:58 PM
