THM200C to 4L60E
Old Jun 25, 2008 | 11:27 PM
screeminchicken's Avatar
THM200C to 4L60E
Hey guys,
I finally got under my car and got the trans code ........ sure enough its a THM200C with a driveshaft that is 3 ft 6" long.
On the side one day I decided to find out in a rather crude way(I didnt have Jacks yet)..... If I got a limited slip or posi on my rear diff......
I has happy with the following results...
But Since I had the wheels up in the air, I turned them around ......bumb..... only one wheel turns at a time and I can even turn the 2 wheels in different directions at the same time. I couldnt find the code plate or stamp on the rear end. Probably covered by mud and oil or rusted away.
Back to brainstorming.....
So far I figured that I would need
1. Late 3th gen or early 4th gen driveshaft
2. Spohn LSX torque arm or Late 3th gen or early 4th gen torq arm.
The consern I have is
The TH200C console and shift lever has only 1-2-D. I would like to keep my console, shift lever and ****. How can this be mated with the 4L60E which has OD. I never seen inside the console box so dont know what all is involved in telling the trans if I am in 1st,2nd,D or OD.
Or does the 4L60E really dont care what position on the console the lever is in and it shifts from D-OD based on rpm, TP or similar.
Since I have to change everything till the end of the driveshaft......and I dont have disc brakes, or posi... I was leaning towards a 4th gen rear diff.
Again the concern I have is this might force me to change my stock wheels. I have stock 15" turbo wheels. I did find a thread here that discussed wheel size and rear axle combinations but there was nothing on this one
Any comments/suggestions is really appriciated.
I really love this site, I was able to make decisions and research and develop a plan for my LSX swap compared to what I did in the last 6 months.
Old Jun 26, 2008 | 10:41 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
You will need a 4-speed automatic shifter. You may be able to keep the 3-speed shifter, but you won't be able to shift it into first.
I'm not completely sure about the early Firebird consoles (having been burnt buying a stick shift cover/boot that turns out to not fit Camaros), but a regular TH700 3rd gen shifter should fit or be able to fit. I swapped the one from my '86 donor car into the '82, it required some modification, but it did work. You may have to swap over the entire later console - I'm just not sure.
Another alternative would be to get an aftermarket shifter like a B&M Megashifter.
Old Jun 26, 2008 | 11:13 AM
Re: THM200C to 4L60E
Thanks.......
I just thinking out loud here
Would this B&M megashifter be able to mate to my Shif ****. Proabaly some amount of fabrication required.
Old Jun 27, 2008 | 02:19 AM
What does a shifter Gate plate do........
Here's a link from summit.
http://store.summitracing.com/partde...rsview=sku&Ns=
The discription sounds promising
Old Jun 27, 2008 | 02:02 PM
Has anybody used this or something similar. The discription looks promising. I have not been able to get a hold of the company yet if this will work with a THM200C shifter and 4L60E transmission.
Here's the discription : Part #: SC2262
Use your factory-installed shifter with a newer overdrive transmission. This conversion kit includes a new laser-cut and hardened detent, lens adaptor and all the hardware and brackets needed for use of the original cable.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
Nervous2
Oct 8, 2015 10:53 PM
LSXcamaro
LSX and LTX Parts
Sep 17, 2015 11:17 PM
IROCZ1989
Sep 4, 2015 11:54 AM
f-bodyz28
Sep 2, 2015 05:03 PM
