LT-1 Transplant out of a B-Body
Car: 1989 FIREBIRD
Engine: 355 SBC 1969 Camelhump Heads
Axle/Gears: 3.42 97 T/A
Has anyone swapped an LT-1 out of a B-body? I am getting the full set up including accessories harness and ecm from a 1996 buick road master. I would like to bring it up to par at least with the corvette LT-1, or even go ahead an do the LT-4 cam (not sure if the LT-4 Hot cam is within the budget to complete the swap). I have a set of the crane gold roller rockers (1.6:1). Is the OBD II actually better or is it going to create issues. Any suggestions on vendors for reprogramming?
I am open to suggestions from experience or knowledge on which direction to go to. All input will be greatly appraiciated.
Transmission: 4L80E/4L80E
Check the sticky in the top section of the forum.
An embedded link: http://www.geocities.com/texaslt1/lt1swap/swap.html
One example:
Screen name: Zepher
E-mail: zepher_ws6@***.net
Year: 1986 Make: Pontiac Model: Trans Am
Swap Info:
1995 CapriceLT1 with T-5 {emphasis added}
-www.transamws6.com
One example:
Screen name: Zepher
Swap Info:
-www.transamws6.com
88SS6SPEED
Nov 11, 2015 07:05 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
