1989 Firebird LSX wiring
Car: 1989 Formula 350 LSX
Engine: 5.3, 234/228 cam
Transmission: Stage II 4L60e, Vigilante 3200
I have a few questions about the LSX swap. The wiring done was not the greatest so i decided to redo it myself.
Does anyone have a 1989 firebird C100 5.7 TPI Bulkhead Diagram?
Also I have noticed that the vehicle will only start if i remove the Gauge fuse. What goes through this fuse that can prevent the car from starting?
Re: 1989 Firebird LSX wiring
Is VATS or something else wired into the Gauge fuse? It seems if i start the car with the fuse out, and then put it back in all gauges work like they should. But the car refuses to start with the gauge fuse in, The Brake bulb test comes on and all gauges test themselves - no ignition.
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
I have a factory service manual for my '89 GTA, if you don't get an answer within a reasonable period, I'll dig it out & see what I can find for ya. (Got family stuff to do tonight though...)
Not a problem man, i figured it out. Turned out the C207 Drk Blue Vats Ground was cut. Grounded it into the new harness and she fired right up. Thanks for the response though!
