LT1 starter wiring help
Old Jul 8, 2008 | 05:34 AM
86LT1's Avatar
Car: 1986 Camaro IROC-Z
Engine: 357 LTx
Transmission: T-56 6spd
Axle/Gears: GM 7.5 10 bolt with 4.10 richmonds
I would like to wire up my starter today, but I'm not sure how many wires, and which ones go to the starter. There is one wire I am sure that goes there because the guy from 350LT1.com labeled it for me when he did my harness and computer, and it is located around the oil pressure, ignition, etc. wires that need spliced into my exsisting harness. When I was looking around my new harness (lt1 harness) I noticed another wire that was similar to the starter wire already labeled. It is purple, the same wire thickness and is located about 6 inches or so behind the plugs that go to the computer, it is also close to the 02sensor wire to give you an idea of where it is. It also has the circular clip at the end which looks like a bolt can go through it. Is this another starter wire? But if anyone knows how many wires i should have for the starter and where they can be found it would be a great help.
Thanks, Ben.
Old Jul 8, 2008 | 08:51 AM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
Re: LT1 starter wiring help
I would also like some input on this
The purple wire im pretty sure goes to the solenoid though.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
Caspar
Jun 19, 2016 11:19 PM
Accerrito22
Aug 23, 2015 07:22 PM
