coolant temp sensor problem
Old Jul 15, 2008 | 03:08 PM
92camarors5spd's Avatar
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
Axle/Gears: strange 12 bolt 3.73's
ok i have had my ls1 in my car for about 2 years now and i have been running aftermarket gauges for coolant and oil. my question is this. for the coolant gauge on my ipc all i need is the temp sensor that is a 1 wire sensor for the gauge off my old 305tbi. will that thread right in to the ls1 heads?
-ryan
Old Jul 15, 2008 | 08:37 PM
bygblok's Avatar
Re: coolant temp sensor problem
no it won't. The LS1 heads use a metric thread and your standard sensor uses an SAE thread. I understand that autometer sells the adapters for that but not sure which one it is. I've seen it here in other threads and also at LS1tech.com as well. I bought autometer gages for my 92 as well but the more I think about it I may just stick with the stock stuff in mine as well(even the tach) and get a shift light to put in the A/C vents to make it cleaner.
Old Jul 15, 2008 | 08:54 PM
macdadyZ28's Avatar
Car: 87 Formula
Engine: '00 LM7
Transmission: 4L60e
Axle/Gears: 3.23 posi
to get around the thread problem, there's a couple guys on ls1tech that use whatever stock temp sensor they had, and tap the heater hose lines (some of them even tap the water pump housing instead).
Old Jul 16, 2008 | 08:38 AM
92ZZ3RS's Avatar
Car: 92 camaro rs
Engine: LS1, 426 rwhp 406 rwtq
Axle/Gears: 9" with 3.70's
i had my factory sensor for a 305 tbi milled down to correct size and then threaded it for the LS1 head. works great.
Old Jul 16, 2008 | 09:23 AM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
i did the same thing except i just ground it down myself and ran a dye down it.
db057
Sep 4, 2015 07:57 AM
TheExaminer
Aug 26, 2015 04:59 PM
fonzie85
Aug 13, 2015 11:50 AM
