Hidden ram air on lsx swapped camaro.....
Old Jul 29, 2008 | 05:02 PM
1987earthquake's Avatar
Car: 1987 Camaro Z28
Engine: 5.3L
Axle/Gears: 3.42LSD
I'm in the process of coming up with ideas for a ram air setup for my camaro. Has any one done this? I'm thinking about utilizing the two holes in the front of the camaro nose.. Any ideas or suggestions please post. I also have to move my maf at least 10-14 inches from the throttlebody so it can't split till after that. I want dual ram air. something like a cone on each hole or actually right above the holes. Similar to how the tpi works but closer to the holes and more airflow...
Old Jul 29, 2008 | 06:15 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: Hidden ram air on lsx swapped camaro.....
Made this for my car using the stock airbox. The scoops are right at the grill openings.
Old Jul 29, 2008 | 06:28 PM
Engine: 5.3L
Axle/Gears: 3.42LSD
one thing about this piece is the fact that the top piece is highly restrictive.. I wonder how hard it would be to reshape it tho.... Might be a viable option..also the part the tube connects to needs to be 4".. The way you have this is it blocking the radiator from getting air from the grille? if so then I would have to change that up because it would cause the engine to run hot. That's the only source of air.
Old Jul 30, 2008 | 04:19 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
I've had it on the car for much more than a year and never have a cooling problem. The scoops aren't right in front of the grille blocking all the air, they come down far enough to get cool air. I'm running that on a V6 so that airbox isn't that restrictive at all for me.
I do know that there is a 4th gen setup that puts 2 cone filters down in front of the radiator. I forget what its called though.
Old Jul 30, 2008 | 09:58 PM
Engine: 5.3L
Axle/Gears: 3.42LSD
You got a pic of how far it comes down?
Vintageracer
Jan 10, 2020 05:33 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
L98GTA87
Aug 11, 2015 06:55 PM
bryan623
Aug 10, 2015 11:33 AM
