Ignition system Q's
Old Oct 7, 2008 | 07:03 PM
SomeGuy25thZ's Avatar
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
Ignition system Q's
What else do I need for a complete ignition system that is for my 383 LT1? So far I am lookin at getting:
MSD billet distributor
MSD 6AL box
MSD blaster coil
MSD plug wires
What else do I need to complete ignition system or is that it?
Also, what spark plugs do I use? What determines the gap to use? My engine is a 383 LT1 with ported heads and intake - can someone point me in the right direction in picking spark plugs or what is the gap I should use and why?
Old Oct 7, 2008 | 11:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Use standard application copper plugs. Anything else is a waste of money.
Old Oct 8, 2008 | 10:02 AM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Re: Ignition system Q's
MSD billet distributor...
Do you mean an MSD Optispark, or will you be running some kind of conversion that uses a distributor??
Old Oct 8, 2008 | 11:01 AM
Car: 1992 z28
Yea, its the opti but on various websites they just title the part a distributor...
Hotrodboba400
Dec 10, 2019 07:07 PM
MM2Robinson
Oct 1, 2017 09:16 AM
383cam
Sep 9, 2015 06:01 AM
Jlanz55
Sep 6, 2015 02:35 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
