GTO LS Engine into 88 Camaro
Old Oct 11, 2008 | 10:26 AM
DeanJ's Avatar
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
Hi Guys,
Has anyone on here swapped an engine from a GTO into a 3rd Gen? I was wondering if the accessory drive will work. Also what about the bellhousing for the T56, slave cylinder ect.
Thanks in advance
Dean
Old Oct 11, 2008 | 11:15 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's mentioned in the LS1 swap sticky, and a search on this subforum for GTO will yield the info you need.
Old Oct 11, 2008 | 11:22 AM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Re: GTO LS Engine into 88 Camaro
Originally Posted by DeanJ
Hi Guys,
Thanks in advance
Dean
The accessory drive, intake, etc will work.
The Exhaust manifolds wont work, and the only cars i see the oil pans fit in is the Nissan 240SX. Your going to need an f-body LS1 pan. Otherwise you should be good for everything else.
Old Oct 11, 2008 | 11:50 AM
five7kid's Avatar
Does that include tubular crossmember?
Old Oct 11, 2008 | 01:07 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
If im understanding correctly, im not 100% sure.
The GTO pan is a front sump. The crossbar would have to be pretty far back for it to clear.
Sheldon
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
