LT1 running very poor....help (95 trans am setup)
Old Oct 14, 2008 | 12:47 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
right now the motor/trans is still in the donor car but i need to figure out whats wrong before i got tearing farther into car.
For some reason the car is showing lean condition sometimes on passenger side of motor, while drivers side is running tad rich.
another issue, if accelerating at 90& throttle, the car will accelerate up to redline no problem....just like stock. Now, when when 100% throttle is applied the car coughs and stutters like its missing horribly
for a while the passenger manifold glows red hot after driving hard.....thing is it only glows from number 6 cylinder back
also, im using datamaster for watch the info on car and nothings jumping out as serious wrong......
weird thing is it will lose PCM signal time to time and also the computer isnt seeing a water temp(reads -40 degress all the time) the e-fans wont come one by themselfs anymore so i had to manually wire them to come on.
i have checked all the grounds and they are good conditon. So do i have a bad computer or bad fuel pump/injectors?
CLIFF NOTES:
90%throotle acceration = runsa bad to the bone
100% thrrotle acceration = runs liike a blown up honda civic
Old Oct 14, 2008 | 12:57 PM
Firebat's Avatar
Re: LT1 running very poor....help (95 trans am setup)
Reading the wrong temp could mess stuff up. Find out if the wires going to the temp sensor are good then test the temp sensor too with a multimeter. Shbox.com should have instructions somewhere to test the temp sensor.
Another thing I would check if the plugs and plug wires. If they are hooked up in the right order and if they are good.
Old Oct 14, 2008 | 01:01 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
its got brand new:
acdelco parts like
opti-spark
plugs
wires
cap/rotor
water pump
and i have checked plugs/wires for correct install like 8909808 times lol
Old Oct 14, 2008 | 01:13 PM
Firebat's Avatar
Did you have this problem before you got these new parts? Got the right gap on all the plugs?
Old Oct 14, 2008 | 03:11 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Could also be a bad injector or dirty injectors also.
Old Oct 15, 2008 | 12:13 AM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
how do you check injectors?
i did use a long screw driver and listened to the injectors and they click all the same speed at idle so atleast they are working somewhat.
Also, it has 97 lt1 injectors on it(maybe they are different?)
im hoping its fuel system, because ive spent well over 600 dollars in the spark ingition area( i havent changed the coil yet though)
Old Oct 15, 2008 | 09:38 AM
Firebat's Avatar
97 should be the same for injectors.
What you do is take the fuel rail off along with the injectors attached. I believe 8mm or 5/16" socket will take the screws off. You leave the fuel rail connected to the fuel lines, everything else can be disconnected like the electrical connectors to the injectors. Then you turn the key to on(but don't turn the engine), the fuel pump should prime and fuel should not exit the injectors. If fuel comes out an injector on this test then that injector is leaky.
I don't know how to check for dirty injectors. I suppose just look at them???
Old Oct 15, 2008 | 02:28 PM
Klortho's Avatar
Car: 1987 GTA
You can generally take them to shop to have them flow tested to see what they flow at and they can tell if they're bad, not flowing like the should etc etc.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
rsrmoore
Aug 7, 2015 08:44 PM
