5.3 w/ a th350 swap ?s
Old Oct 15, 2008 | 11:22 PM
kizmaro89's Avatar
Car: 89 Camaro RS
Engine: LM7
Another LSX swap started. I picked up a 5.3 yesterday and have a fresh Th350 that i would like to make use of. i've been doing a lot of searching and cant come up with some answer.
1)Will the S&P or Trans Dapt style motor mounts work? I've already deleted A/C so the k member clearance isnt a problem.
2) will the B&M torque arm kit still work with an lsx swap. Not sure if the motor mounts will move the transmission location.
Old Oct 16, 2008 | 02:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not sure about the S&P, but if you've removed AC, the TransDapt ones will work. They should locate the bellhousing in the same place within the chassis. The problem with the plate was it ends up where the AC sits.
You will need an adapter to fit the TH350 to the Gen III engine, but I'm not the right person to provide details.
Old Oct 16, 2008 | 07:47 PM
kizmaro89's Avatar
Car: 89 Camaro RS
Engine: LM7
Re: 5.3 w/ a th350 swap ?s
thanks for the help, I'm going to order the TransDapt mounts. As for the trans. adapter this should be all i need after i elongate the flexplate converter holes. http://store.summitracing.com/partde...HP3795&FROM=MG
Old Oct 18, 2008 | 09:14 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
I'd recommend the GM version over the Hughes - looks like it attaches a little more securely... See here: http://jeepinpete.com/engine_trans_a...ans_adapt1.htm
ZZ3Astro
Aug 13, 2019 12:57 AM
neilb
Oct 4, 2018 12:36 AM
customblackbird
Oct 1, 2015 04:30 PM
E Rod
Aug 28, 2015 05:17 AM
jharrison5
Aug 19, 2015 05:53 PM
