Please help identify on LSx
Old Nov 9, 2008 | 11:07 PM
midnit's Avatar
Car: 86 IROC
Engine: LS6
Axle/Gears: 3.08
As I said previously I got my engine as a longblock. Technically its an LS6 but I doubt that matters for these questions. Anyway I have a few items I need help identifying.
Please refer to the attached photo:
1. I assume this is supposed to be capped, the cap is torn so I should replace correct?
2. What goes here? I have no idea what goes where this orange plug is.
3. Does this stay capped? If not, where should it go.
4. I believe this is the PCV which gets hooked to throttle body correct?
Thanks for the help guys. I just got the engine mounted in the bay so gonna start a swap thread shortly.
-Robert
Old Nov 10, 2008 | 03:01 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Re: Please help identify on LSx
1. Some guys cap this and claim the block is vented well enough internally and this is not needed but I piped it from one valve cover over to the other just to be safe.
2. The stock oil pressure sender goes there but its not nec to run the engine ( meaning the PCM wont throw codes if you dont hook this up )
3. Hooks up the the throttle body
4. Yes I'm pretty sure thats the LS6 style PVC which gets hooked up to vacuum but you'll want to confirm that over at LS1tech just search out LS6 PCV and you'll find lots of info
Old Nov 10, 2008 | 05:29 AM
midnit's Avatar
Car: 86 IROC
Engine: LS6
Axle/Gears: 3.08
*sigh* Its seems like its always just one more thing to buy
cam-
So got another question.
Q1. On the back of the intake, is there anything specific the little vacuum line goes to? I assume the large one goes to the brake booster.
Q2. What did you use for the air intake tube, elbow, filter, etc. (havent searched on this, sorry if its out there)
Old Nov 10, 2008 | 07:24 AM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
For my intake tube, i use a 4" Sewer pipe 90* elbow, some rubber connections to go from my MAF to my filter. Its not perfect by any means, but it gets the job done.
Old Nov 10, 2008 | 07:42 AM
midnit's Avatar
Car: 86 IROC
Engine: LS6
Axle/Gears: 3.08
It does sound funny but if it works and looks ok...I'll have to look into that
Old Nov 10, 2008 | 08:46 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Theres pics of my intake in the sticky and yes the big port goes to brake booster and the little one i used for my HVAC controls
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
Buggy Disaster
Sep 22, 2015 01:15 PM
Linson
Sep 21, 2015 01:08 PM
