My Swap :(
Old Nov 21, 2008 | 03:56 PM
Saleen85's Avatar
My Swap :(
Well ... my swap took a turn in a different direction
Old Nov 21, 2008 | 06:53 PM
Jonnybravo55's Avatar
Car: 1991 RS Vert
Transmission: 4l60e
Re: My Swap :(
That really sucks man. I'm sorry this happened.
Old Nov 21, 2008 | 07:08 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Re: My Swap :(
its fixable................ive seen worse.....................sorry that happened tho but fix it............150.00 for aftermarket fenders<pair> and im sure you can dig up a used front bumper cover etc
Old Nov 21, 2008 | 07:56 PM
a1990camarors's Avatar
Car: 1990 rs 1992 z28 1995 jeep
Engine: no engine, 383stroker, inline 6 4.0
Transmission: none, t5, auto
Re: My Swap :(
i know this is going to be in bad taste.... but how much for it as it sits...if you dint have insurance that is. do you know if the frames tweaked? if you decide its just going to be a no go ill be all over those parts but my condolinces on the wreck it always sucks.
Old Nov 22, 2008 | 09:29 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Re: My Swap :(
Sorry to see that man. What happened?
Old Nov 22, 2008 | 10:24 AM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Re: My Swap :(
That has to hurt. Good luck on getting it road ready again.
Old Nov 23, 2008 | 12:38 AM
Saleen85's Avatar
Re: My Swap :(
the frame is bent pretty bad. If you look at the picture with the hood up, the strut tower is pushed into the brake master cylinder. At minimum, it will need to be put on a frame machine and attempted to be straightened. Unfortunately, it's cheaper to pull the engine/trans and put it into something else. I've got a 1983 Capri RS that's sitting with no engine, or I am attempting to locate a hardtop thirdgen.
As for it being for sale, I've put a few posts in the classifieds section. Engine/trans/ECU/Harness are pending a sale right now.
Old Nov 23, 2008 | 11:44 AM
89RS305TTops's Avatar
Car: 87 Camaro Z28
Engine: LB9
Transmission: 700-R4
Re: My Swap :(
man that really does suck. my condolences on losin the car. btw that looks like a really clean swap you did, massive props on that
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
